PSR800 Clear a Scan List
mikey60
Oakland County Michigan
If you're trying to clear the configuration of the scanner, you can just delete the CDAT folder from the SD card.
If you're trying to delete the items in a particular scan list, you would pretty much need to do that in the software that comes with the radio.
Mike
mikey60
The software is the easiest way to do it.
You can change the scanlist memberships by navigating to the object in the browse objects item, then press SEL, then Menu, then scroll down the the Set Scanlists items and adjust them there. You can only do one object at a time that way.
Mike
robschonk
Avon, NC
If you want to delete everything in a scanlist, bring up the scanlist, use standard windows selection techniques to highlight all the items, then click Delete Channel.
