Putnam Co TRS
seagravebuff60
Short Bus Reject
New York State
There definitely is no site 0. I am using UT to monitor, but my SDS doesn't even show site 0. I don't know where you came up with that info.
seagravebuff60
Short Bus Reject
New York State
That's okay. It was a simple mistake. Im guilty of that too. I'm just surprised you got audio while programming site 0. But yeah, programming it as Site 1 is correct.
GTR8000
NY/NJ Database Guy
BEE00
If you're referring to an SDS200, there is nowhere to program a Site ID. In fact there is nowhere to program most of the trunked parameters such as SysID, WACN, Site ID, etc. The only thing you program are the control channel frequencies and optionally the Site NAC, which defaults to Search and thus is not necessary unless you have co-channel interference which is unlikely. I'm not quite sure where you were programming any 0 or 1, to be honest. The SDS's display will show the Site ID if you have it setup to do so (along with the aforementioned other variables), but that's pretty much it.
K2KOH
Putnam County, NY
No the site name when entered manually can be named Site 0. I would show you a screenshot but I already changed it
pro106import
Milford, Ct. perched high above Long Island Sound
The site "name" can be whatever you "name" it. The site "ID" comes from the control channel data stream and cannot be made up. My site name here in the photo is 471.2375 ( I named it the control channel frequency). The site ID in the second row in the bottom right says 1. That is what GTR8000 is referring to. It cannot be inserted or changed.
