tush
Ok, I know that this has been discussed before, and that is fine and dandy. As this may be along the same lines.
I want to use PVC pipe (sched 40 solid) to build a mast. Yes I know that it is not recommended. At least the smaller diameters. The questions come from using larger sizes. Ex, Using a 4" 10 foot with a 4-3 coupling, then a 3in 10 foot section, 3-2 coupling and a 2" 10 foot section.
The intent is to have the pipes nested do that it has 12 inches of overlap and a bushing from one size to the next, shortening the entire structure from 30'6" to 28'. this mast would be used for GMRS, RTL1090, and a receive only for 155Mhz (local Police freq)
This mast has the ability to be guyed if need be.
Thoughts?
Thoughts?
