PX888K Help!
SA0CBP
I have the same problem now, and none of these salutions works for me.
The radio is locked. I can change freqvency but not band . And i cant get in to the Menu. I push Menu and turn the vfo Wheel but nothing. All Keys are dead etc.
dbirky
White Pigeon, MI
PX888K
You need to change the Work Mode-A and Work Mode-B settings in the Optional Features menu from VFO to Ch. Name. [See image] This will set the radio to power up in the correct mode to display the channel alias names.
Pressing the # key sets the radio to the call channel. You can change this by going to the VFO/Call menu. You will notice that the two frequencies you had on your display before are shown as VFO A and B.
Please feel free to contact me if you have any additional questions.
- Rob
Does this alleviate the accidental press of the # key? I have 6 of these in the field that I locked the keypad on but people accidentally hit this and I have to walk them thru fixing it. Any way of locking this out as well?
Thanks!
SA0CBP
Yes, i turned of this function in the settings on the computer.
And after this i had no more problem.
Sparky5019
Ok so I'm new here and new to radio altogether. I bought several of these and I can't get the programming software to work at all. It won't read from the radio or write to the radio. I have no com4 on the computer for USB. The cable is domestic and seems to connect fine meaning the software says its reading or writing then shows an error saying check the connection. The computer registers that there is a device connected to the port though.
Help!!! Please!!
Thanks so much!
KD8DVR
Columbus, Ohio
Help!!! Please!!
Thanks so much!
You will need to install the proper driver for it to work., The driver can be acquired at the previously mentioned Yahoo group. Standard prolific drivers will not work. You need a earlier version driver, or an FTDI cable to get it done.
Sparky5019
This is not the Chinese cable but one I bought from www.bestchoice preps.com domestically. His explanation was the cable worked for them as is. I did try that yahoo group but it's closed so I have no access.
KD8TOV
Lowell, Mi
Ok, I'm next.
I just bought 2 more px888k ' s from a guy who couldn't program them.
I thought it would be no big deal, I can program manually.
Wrong, they are locked out and I don't have the software, because it doesn't work, what's new.
So I'm looking for help.
I'll even mail them to someone to unlock them so I can manually program.
KD8TOV
Lowell, Mi
"KD8TOV you have to have the software to unlock them. Locking in the software cannot be undone with the keypad."
Thanks, correct.
I can get my computer to recognize the radio but they won't transfer from one to the other so I'm still stuck.
I have a request into CHIRP to take them and create a support for that model, which they don't have yet.
Hopefully it goes that route because I don't have the mental capacity or computer knowledge to make this happen.
KD8DVR
Columbus, Ohio
The Chirp request has been in for years... no responses. There was even someone who wanted to send in a radio for them to use.
KD8TOV
Lowell, Mi
I probably should get a different cable.
Chirp doesn't look promising does it?
I'm still hopeful someone will pop up and say "yeah, I can do that".
JeepZJ
Idaho
I just got a new set of PX888K and downloaded v1.03 of the software. I loaded my channels into the first radio no problem. Now I can not access anything in the Menu. If I hit Menu it shows up but when I press any other key it returns to the channel I was on.
When I turn the radio on it shows 7.9v on the screen then goes to the main screen.
At the top is the letter w and the battery power
Next line has a M with the channel number below it, Then next to them is a Large letter A with the name of the channel MURS1
Next line has a small letter H and larger letters MURS1
link to photo of screen http://shtfinfo.com/images/888k.jpg
KD8TOV
Lowell, Mi
I have a new cable coming and I hope to be able to remedy this situation.
I'll keep you posted.
I order my px888k's from 409 shop for the new ones and they come non programmed so I am able to manually program them to my desire, no lock out.
The bad set I have, the original buyer said he got them from Alibaba.
KN1IGHT
Earth: Undisclosed Location
Hi guys,
I know I'm new here, but I've worked with PX888K's v1.01 software & v1.03 before on my own PX888K & a friend's as well.
Keep in mind, this is not CHIRP. This software is named PX888K (v1.01) & PX888K_UV (v1.03
Sadly, the website I got my software from doesn't have the page anymore, but the download page did warn me, that if you use v1.03 you will "lock" up the radio, as JeepZJ has described, and you will need v1.01 to unlock it.
To unlock it, you need v1.01 of the software, and follow these steps:
1. Connect your radio to your PC
2. Select your COMM Port
3. Read the radio
4. Click on Optional Features
5. Make sure Manual is checked, in the bottom right corner of the optional features window.
6. Click OK
7. Write to the radio & disconnect from PC
8. You should now be able to access the menu.
Note: I have confirmed myself, when Manual is not checked, the Menu is virtually useless, as it behaves as JeepZJ described above, and it must be v1.01, as v1.03 does not have the Manual setting in Optional Features
~ KN1IGHT
P.S. I've attached a screenshot of the Optional Features window & highlighted in red what should be checked.
KD8TOV
Lowell, Mi
Knight you are correct.
As I have been told by Puxing and 409 shop,
1.01 is not available any longer.
Only if you can get it from someone who has it can you make it work.
Sad but true
KN1IGHT
Sad but true
KD8TOV,
I do have the installer program for v1.01, but am not sure if I can share it or not, as the website I got it from was not the manufacturer's website.
