Quansheng Quansheng UV-K5 (8) Password for CPS
KC0CCB
Whitewood, South Dakota
Hello! mine has done that too! i solved that today, i compiled the FW NOGIT after edit the line that includes delete AES passwd at the makefile, then i flashed the fw, then i flashed the original one and was fixed :) ,tell me if you wanna mine already compiled .bin.
What’s the link to the program ?
KC0CCB
wr858pete
Maybe I could / should try your compiled bin file first.. if I could ?
did it work? let us know please
hello dan, is there a way to find out what that pass code is with using that firmware? i have been seeing more and more k5(8) with this issue within the last 2 weeks on a fb quansheng group, after either egz or IJV being installed and than going back to stock firm, i found this thread after spending 4 days trying to figure out what went wrong after installing egz 0.22 and my screen completely pixeled out i even had to have quansheng remotely connect to my laptop to unlock it they insist they do not use a passcode with the k5-k6 for csp to work
Daniel1996
São Paulo, SP
Well, i had this problem after flashing the IJV 3 at the radio, then i was tired of all settings and tried to go back to stock, then that happened. Egzumer i have little to zero experience, i used for about an hour, than flashed the IJV.
wr858pete
STOCK, Portable radio update tools (V1.1the stock program won't flash daniels firmware, you need to use kprong or use the web browser flasher to load new firmware to the radio cps only reads what's on the radio and lets you program it
merlin
DN32su
I tend to go back and forth between stock latest firmware and latest IJV. It gives me everything I want.
merlin
DN32su
what flash program are you using
I use CPS stock v.1.0.38 and K5prog_win V0.1,27, both on windows 10 with no issues at all.
Firmware is stock or IJV.
I have never encountered a password situation but a remark on Quansheng website says try qs12345.
