Question about NXR-5800
jatrujil
I work with a city entity that currently has a Kenwood NXDN trunked system. It has two sites, and is a Type C, Gen 1 system. Currently all the repeaters are NXR-800k. Would the NXR-5800 work in this system if I had to replace an NXR-800k?
kd4efm
EL98 Florida
Yes, will work mixed also.
I run mixed here in Florida with, 800 and 5800's in a stack.
EWC_BDN
Key differences are it uses KPG-D2, but it works the same as KPG109d.
Biggest gotcha with them is in Very narrow BW you have to hook up the Ref In and Out BNCs for it to work. well it works without it, but only if the Control channel is number 1. If you have it rollover it to 2 or 3 it will lock up and not work at all without those BNCs.
Source, i didn't do that and system worked ok in the shop for two days. installed on site and it doesn't work at all anymore. Kenwood says oh do this and it works fine now.
I think the only visual difference is it has a USB-B Port instead of a serial one.
jatrujil
Sounds good. Our system is the Gen 1 type C and it is running Very Narrow BW. the NXR-800 repeaters require a specific firmware for trunking KSPG-91800. Would this be the same for the NXR-5800?
kd4efm
EL98 Florida
800 and 5800 have the same VERSION, but are different.
Also, the trunking g option is part of the activation file for a system.
Not a firmware thing.
