Question on MCC7500 Consoles
RadioGuy3007
I have a question related to the MCC7500 console. Our state is going live in some areas with a new 800mhz P2 P25 system. I am curious how patching works. Currently one of the local PDs is unencrypted on 800 but it's passing back through VHF with encryption and showing the dispatch console ID and when an officer keys up it continues to show the console ID. I am genuinely curious how this works. I would think if they are encrypted on one channel they should be encrypted on the talk group. This new system is supposed to utilize ÆS encryption with OTAR. Since the system is still being built is it possible the encryption is not built out or ready?
TJX400
Probably being overlooked. Patching between two talkgroups on one system just tunes radios on either talkgroup to the same frequency. Patching two systems together essentially just opens the air when audio is heard, like VOX. I'd imagine they will fix it as the system continues being built out. In this case it seems like the VHF side is a different "system", so when it's patched to the 800, the console is just repeating the audio under it's own ID.
jeepsandradios
East of the Mississippi
All depends on how the system is configured. If they want secure on P25 they can. I have multiple patches with clear/encrypted in the mix for various reasons.
Ubbe
Stockholm, Sweden
Are you sure it's the console id and not the patch id? When patching between two systems it's usually done using analog audio with VOX or EM signaling but no user ID are passed over the link. Only the mechanical patch id and the TG it is linked to will be known. Any encryption can be added by the base station at either end.
If it is the console ID then you are listening to the system that has the dispatcher and the mobile are transmitting from the other patched system, not able to show it's own user id and the console id will still be shown.
/Ubbe
GTR8000
NY/NJ Database Guy
BEE00
/Ubbe
Patching has come a long way since what you've describing. Modern systems, especially when patching P25 resources (conventional or trunked) together via an ISSI link or system consoles, is normally IP/digital end-to-end, not "analog with VOX". The IDs of the subscribers on either end of the patch are normally passed through that link/patch.
