AF6LF
On the back of the iCOM IC 730 there is a 24 pin female you can use to run an amplifier - e.g., pin to ALC; pin to/for Relay connection. ? Question is what is the pin numbering system for/on this connector. Manual identifies what pins to use - BUT doesn't show you where/how the connector is numbered to install the connections. ? Anyone know how the pins are numbered??
Larry F
W6EF
Lfibich@sbcglobal.net
Larry F
W6EF
