Quick Key Help
pinhead
CINCY OHIO
Yes i just got my bc 996t to day an it says that ....CINCINNATI OHIO.....is all ready preprogramed in the radio an the quick key is ...46.....iam pulling my hair out. can some body tell how to put this in thank you. EARL...
(.no) Key then 4 6 (this is on my 396) I think it should be the same on the 996
pinhead
CINCY OHIO
I all ready tried that .still cant get it to work. any body else got any ideas..
Can you enable any other System this way ?
Also per Manual
Follow these steps to lock out systems.
1. Press and hold F.
2. While continuing to hold F, rotate the Scroll Control to select a system you
want to lock out.
3. While continuing to hold F, press [L/O] to lock out the system.
4. Repeat Steps 2, and 3 to lock out additional systems.
Also found this in the Maual
Locking/Unlocking Systems
Follow these steps to lock out a system so that it does not scan even if its quick
key is selected.
1. Tap F to switch to the Function Mode then rotate the control to select the
desired system.
2. Press [L/O] to temporarily lock out the system. Temporary L/O appears. Or,
quickly press [L/O] twice to permanently lockout the system. Locked Out
appears.
3. To unlock temporarily locked out systems, turn power off and then back on. To
unlock permanently locked out systems, repeat Steps 1 and 2. System
Unlocked appears.
You should be able to use that to unlock it.
give it a try and let us know if this works
N1GTL
CT
From page 21 in the instruction manual:
For two-digit SQK's, first press [.No], then enter the two-digit SQK.
N1GTL
CT
Those were the correct instructions for the BCD996T. I just tested it on my scanner.
Hit the [.No] key followed by the two-digit number to lock/unlock the system assigned to that number.
If you try to unlock a group that is not defined, you will get three beeps. Maybe there is no group 46 in your scanner?
rbm
Upstate New York
Make sure you hit the three keys in quick succession or it won't work.
You may wind up turning on system 4 and/or system 6 instead.
.46
pinhead
CINCY OHIO
I Was wondering if you do a reset onthe bc996t will it delete all the preprogramed states in the radio. thank you.
pinhead
CINCY OHIO
Well guys thanks for all your help the reason it did not work is i deleted all the states out an had to do another reset an push yes an then hit ..o plus 4 6 keys an there it was cincnnati ohio.. thanks every body .you were all correct i pushed no when i should have pushed yes on reset. dummy me.
