hrsfoto
I have a conventional system (0) with 10 groups (1-0). It has been working fine. One day I hand deleted some systems and other stuff. Now group 0 in this system only stops on frequencies in the 42.00 range (CHP) and below and not on any of the other frequency in the same group. There are 55 total freqs in this group - PD SO etc for Butte County CA. If I copy this group to (1) it works fine for group 1. However if I L/O group 0 group 1 also locks out and the scanner says nothing to scan, and vice versa. If I do not load 0 into the scanner than it works OK.
I have also reprogrammed scanner to default (as new) and reloaded from my file, same problem. I am using Freescan but don't think that was what screwed up the scanner - it was me on the keyboard but I don't know what I did.
So what did I do wrong? and how to fix?
Thank You
hope this makes sense explaining
Thank You
