BCD436HP/BCD536HP: Quick Programming Question - 436HP
emsflyer84
Central NH
Hey all, using ProScan to program my scanner (just make some updates really). Somehow I managed to get myself in a situation where when I select Quick Key 1 to start scanning that list, it looks like there are selections that are not turned on, next to F1 (see first photo. All the rest of my Quick Keys work fine and there isn't anything showing up next to the F1 when I turn on the other Quick Keys (see second photo). Because of this, when I turn on Quick Key 1 it still says Nothing to Scan, I assume because the items next to F1 are not turned on. I believe I programmed all my systems the same way, I can't figure out what I did different for the system assigned to Quick Key 1. I also can't figure out what those items are that are next to the F1, or how to turn them on. Sorry, I'm fairly new to this model and not super familiar with the programing lingo for it yet. Thanks in advance.
RandyKuff
Lorain, Ohio
If your using Sentinel are the Quick Key numbers your using enabled (Checked) in your Profile...
ProScan
Software Provider
Ontario, Calif.
Can you double check your FL Quick Key assignments before we address the "Nothing to Scan" issue as many things can cause that. It may fix itself if the FL QKs are straigten out and turned on.
The 1st screenshot shows FL QK 10,11,12,13,14,15 assigned but not on.
The 2nd screenshot show FL QK 20 - 29 not assigned.
Can you press the "0" key to see if the FL QK 0 to 9 keys are assigned or mainly FL QK 1 ?
ofd8001
Louisville, KY
You might try pressing 11 eYes and I think you'll be in business.
If you assigned a Favorites List Quick Key of "1", then you should have seen something like F0:*****
The first digit after the F (and S and D for that matter) represents the "tens" in the digit after the letter.
So F0 is for FLQKs 0-9; F1 is for FLQKs 10-19; F2 is for FLQKs 20-29 and so on.
Asterisks (*) as noted above, mean the FLQK is assigned but is toggle off. Dashes (-) means the FLQK is not assigned. A digit, like 1 means the FLQK is assigned and is toggled on.
Logikal1
WD4GAB
Just my experience, ProScan is great for scanning/logging but Arc536Pro is best for programming the 436.
ProScan
Software Provider
Ontario, Calif.
We try to make ProScan the best. Is there anything that can be done in ProScan to make it better or address a certain issue.
