Quickkeys:
erikk1840
BCD325P2 To use system quickkeys, you must enable group quickkeys for trunked sites and conventional systems, for them to work. How did I learn this? I did two hours of trial and error. quickkeys.png
tvengr
Well Known Member
Baltimore County, MD
Here a PDF file that will answer all of your questions about using quick keys on the scanner:
  • Uniden Scanner Quick Key Instructions DMA.pdf
Ronaldski
MI DB Admin
Bay City MI
You do NOT need to use group quick keys. I actually use the 0-9 as regular quick keys, I actually don't use group quick keys, I just use the 0-99 as quick keys, so far I program in 0 through 80 as I put in ~3/4 of MI. Each quickkey is a different county or agency.
erikk1840
Are you using a BCD325P2 ?
Ronaldski
MI DB Admin
Bay City MI
While no, I use a 396xt, but I use the same programming setup for 325P2's that many have, who come to me to be programmed. 396xt is phase I capable only vs yours is phase II capable.
I use freescan software.
