I found the article interesting as I rarely if ever use my R30 on anything below 150MHz. I bought my first R30 to compliment a Uniden 436 and a TRX1. When I get some time (?) I should probably write down some of my views on pros and cons of each. The R30 is definitely one of my favorites.
Highlights include the excellent sensitivity (often the case with Icom, as an R2 and R5 owner too), its probably the easiest digital scanner to learn to use IMHO, and the dual-watch has proven to be a surprisingly helpful feature. It is also - to my knowledge - the only receiver that does NXDN4800/Nexedge very narrow slectivity down to 3.125khz 'properly'.
Negatives of me are no DMR (that's by far the biggest -ve), no automatic CTCSS/DCS tone decode, I coul do with more memories and less restrictive memory allocation per bank, the battery life is more limited than I'd hoped for, and its cost given its more limited features. In short, if you dont need DMR its great, if you do then look elsewhere.
