Just got my R8600. Great receiver and still learning but I soon discovered, the radio lacks 1 hz dial tuning. The brochure advertises it and the manual shows it on page 14-1 but the radio won't do it. I contacted Icom but they were non committal to fixing it. The 7300 does it as do all my older Icom boxes. Why doesn't the R8600 do what Icom advertises? I told them that we don't use these radios just to listen to broadcasts, etc. It's also an instrument. This is a really bad look for Icom IMHO, to advertise something so simple and yet not commit to fixing it. I'm not asking for DMR or something that will impose license fees on Icom, I'm simply asking for what they advertised and what they have on cheaper and vintage radios. See brochure snip below.
I take it as, the R8600 does exactly what Icom advertises, but not as you interpret the advertising.
I do understand your want (and I would like it also) for 1 Hz tuning steps, it gives smoothness to the tuning sound, if nothing else, and fine tuning, but realistically the radio is not accurate, nor precise, to the 1 Hz resolution anyway. I mean, unless you have the radio disciplined to a good external reference the 1 Hz resolution is wasted. The manual lists the frequency stability as "less than 0.5 ppm", but this means at 10 MHz you could have 5 Hz of error and still be in spec. In the ARRL review they found that at 10 MHz it was dead on, and at 50 MHz it was 12 Hz off, at 1 GHz it was 245 Hz off. This is twice as good as it could be, and still be in spec.
It may come down to, resolution is not the same as tuning steps. At least, that is how I interpret it all. The only place the manual says anything about "1 Hz" is when the manual (and brochure) discuss resolution. One place in the manual it says that the resolution is 1 Hz and 1 Hz is never mentioned again. If they had meant that resolution and tuning steps were the same thing, why would they have them both independently discussed in the manual?
Everything in the manual that discusses tuning steps mentions 10 Hz as the most fine step available. It does not specifically say "10 Hz is the smallest tuning step" but it never mentions anything smaller than 10 Hz.
The manual could do a better job of defining all of this, for example if it clearly lists the tuning steps available, say in a table. They have done that on past products.
I am guessing you have not owned a wideband radio from Icom before? The radios that the R8600 replaced, things like the R8500, R7100, R7000, even the very expensive R9000, also did not have 1 Hz tuning steps. However, none of those radios had 1 Hz frequency resolution, either.
T!
