grueic8600
- Joined
- Mar 8, 2021
- Messages
- 16
what does the waterfall show me? specifically the blue background where there are no stations spiking.
i have a 1m active loop antenna, indoors. and i'll rotate it occasionally. sometimes when i rotate it the blue background of the waterfall will fade, sometimes to black depending on where i have my ref level set.
is the blue background of the waterall noise? it doesn't seem to be as tonight i noticed i was able to get stronger signal from quieter stations when i rotated the antenna. but the blue background was brighter, or more of it.
so now what i'm thinking is, the blue background - in fact the whole waterfall shows overall signal strength, which is why it all brightens up when pre.amp is turned on or when i increase the rf gain.
so i used to think the blue background was the noise floor and i could tune my antenna rotation by rotating the antenna until i visually saw the blue get weaker or disappear. but it never really sounded like there was less noise. the noise for the most part sounds the same compared to the stations, just overall weaker or stronger.
since the loop has nulls, all i was doing was weakening the signals i was getting, but still getting the stronger ones. am i correct about this? in otherwords, if i want to pick up some weaker stations, rotating the antenna will help me get them. but also rotating the antenna helps eliminate nearby noise sources but could be at the expense of not getting weaker stations.
thanks!
thanks!
