With the Uniden 200 I pick up about 3 of the weather channels where I live. With the Icom R8600 I can receive all the weather channels clear with the same antenna. But then your looking at a 3 to 4 times price difference.
for comparison, my AirSpy SDR beats my Icom 8600 on the same antenna in just about everything above 118MHz....
while I really like the 8600, and i certainly wouldn't sell mine, the price vs. performance ratio is incredibly poor compared to any high(er) end SDR.
is what it is.
doug
Most normal users would probably want other receivers to actually go silent while you transmit, but not to burn up of course. You do not want other audio sources going into the mic while your are talking, that's just rude and unpolite to those who listen to your transmission. The 8600 are a good specification receiver so no argue about that.If an Airspy didn't go up in smoke from being that close to an 85 watt transmitter, it would not receive anything and probably not on any band let alone 2MHz away in the same band.
I have various SDRs here including an RSP2pro and they are cracker jack toys compared to the R8600 in every way.
There is no other tunable consumer receiver that can do this and many repeater receivers can't even do this...
Thanks for anything you can offer!
This really depends on the listening you want to do. If it's HF, I would look at the SDRPlay products: Products – SDRplay
The Airspy HF+ is a really good HF SDR as well - a little cheaper than the SDRPlay products. airspy.com
if it's VHF/UHF stuff, I would go with an Airspy R2. Hands down. SDR# with it's plug ins (scanner, P25, etc.) are amazing --- and compatibility with DSD+ is "built in" so to speak (with the DSD+ Fastlane version) I use 3 Airspy R2s... every. day. 2 running DSD+ and one running SDR# with the fast scanner plug in.
I have said it before, and I'll say it again - my Airspy R2 hears signals that my R8600 doesn't. Don't get me wrong - the R8600 is an amazing radio... is it a $2000 amazing radio? Sort of.
doug
I'm Just starting to experiment. I have my R8600 hooked to a long wire antenna, an IC-R30 with the stock antenna and an RSPDUO connected to a youloop antenna. All three receivers and the loop are installed in the basement. So far all three receivers seems to be picking up the same signals. The signals do not have the same strength but are clear enough on all three receivers. I also tried the long wire antenna on the SDRPLAY and honestly i did not notice any difference when compared to the loop antenna....I will experiment some more....
