Racom
gator
Mitchell,SD
Has anybody downloaded Racom data into unitrunker.I downloaded and have the folders with everything in them but cannot get them to load.
tyytor
Wyoming
by saying load do you mean the files from trunker to unitrunker or the files from this site??
if you mean trunker there is a perl convert program to change the format but you will have to rename the file after coversion,does that anwser you question?
or is it some thing else if so ??
i have been running Racom on unitrunker for a few months now with good decode :)
what files are you haveing problems with??
gator
Mitchell,SD
I want to be able to see the takgroup labels in unitrunker.I have everthing dowloaded from this site but nothing shows up in the program.
tyytor
Wyoming
ok, does it happen when you first start the program?? if so it is a glitch just change to a different part like [ B] or and back again and they should show up it in the 9th beta
hope that helps, LOL
gator
Mitchell,SD
No the program starts fine and it shows the system being decoded just fine but cannot get talkgroups to appear.What do you mean by b or u
Run Unitrunker ... tune to your local RACOM site. Confirm system is being decoded in program display.
From the main menu, [F]ind -> ystem ...
Skip over system Id and type.
Set RR DB SID to 1006; fill out your RR DB user id and password.
Select [D]ownload from the menu.
Talkgroup labels should appear after 5 or 6 seconds.
gator
Mitchell,SD
That is the problem I have the data downloaded like I said in my first thread and have the data folders for Racom but for some reason cannot get it (the talkgroups) to load into the program.
It may be loading the data under system 0 which is why you don't see it. Edit the sysid field to match the currently monitored site ... then select [D]ownload. That should force the data to download into the specified system.
gator
Mitchell,SD
Still having trouble getting it to fly so lets start at the beginning.This is what I have for a screen before the download with files that say 90D in my unitrunker folder
gator
Mitchell,SD
This is what I put in before I go to download with my username and password of course.Then I download and get files that say EDACS900 with by the way the grp file with all the groups in it.
Before
gator
Mitchell,SD
Thankyou Rick,
I tried that along time ago but for some reason it did not work I dont know what I did right here.I have the groups in there but should this system be in the system log under S?
gator said:
Thankyou Rick,
The list of logged systems is a snapshot of your working folder at the time the program started. If you re-start the program ... the system will appear (with the updated labels).
