Radio Dummy with Pro97 desperate for assistance
LindaFarrell
Oklahoma City, Ok.
I have a Pro97 which I took to Radio Shack to program. What a mess! I finally found a way to delete all frequencies they put on one band (although not sure what I did). I programmed the three frequencies I wanted in it and I get audio on Santa Fe Station but not on Will Rogers or Bricktown. Can somebody please tell me what I did wrong?
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
Access to a cheat sheet programming short cut for the Pro-97 is under my signature below.
Using PGM then MODE set the bank to EDACS. Then program the following frequencies in exactly the listed order starting with channel 01 as 866.0875 in the selected bank. Use UP or PGM to move to subsequent channels. The last channel number should be channel # 18 with 868.9750.
866.08750
866.61250
867.12500
867.62500
868.25000
868.75000
866.18750
866.71250
867.26250
867.85000
868.42500
868.92500
866.43750
866.98750
867.56250
868.06250
868.47500
868.97500
After frequencies are entered, press TRUNK then key in the talkgroups per instructions in the Programming Shortcut. Entering Alpha (Text Tags) procedures are listed in this shortcut also.
