Radio Shack 9-Volt Vehicle DC-to-DC Adapter For PSR-500
qc
San Francisco Bay Area
HI, I would like to find out if any one has tried the Radio Shack 9-Volt 273-1863 with 273-1706 Adapt plug C .I was thinking of buying it for my PSR-500 and emailed GRE and answer from there Engineer was this
"It is good for physically. However, the 12VDC to 9VDC
adapter is switching type one. It generate a lot of noise.
So that, it is good to use ONLY for charging but not for receive"
PSR-500 BCD996T
6Paul21
Florida
12V DC to 9C Cigar lighter
I have been using the RS that you mentioned with no problems. I have Pro 96 & PSE 500 with a wye and before that two Pro 96's for about 3 years now. Just make sure that you have the polarity correct and try using them without the antenna first as the antenna does go to ground.
Ed
LEH
Yorktown, Virginia
HI, Thanks for the Reply I will go ahead and order the Radio Shack 12V
It's a 12 volt down to 9 volt, just a quick reminder to your ordering the 12V.
Normally these are in stock (along with the tips) at your neighborhood RS.
