Pro-106: Vehicle adapter for PRO-106/PSR-500/WS1040
CarvinDude
I'm trying to locate a correct vehicle adapter for my PRO-106. I purchased several from flea bay that say they will work with any of the above scanners however just to be safe I checked their output @ 13.8 volts with my bench power supply and none of them output 9 volts. They all seem to be directly connected to the 13.8 cigarette plug with no voltage drop at all and excessive current is a concern. All of the above say "9 volts dc" Is it safe to assume that I would toast my scanner with 12 volts @ x amount of current. Whistler doesn't even show them as an available item. Any suggestions would be appreciated.
Cheers, Peter
gmclam
Fair Oaks, CA
I've never liked the cheap vehicle adapters as they output unregulated voltage. Consider that a vehicle is "12 volts" when the engine is not running, but a typical voltage when the battery is charging is more in the range of 13.8 to 14.2 volts. Do the math; if you drop 12 volts to 9, you can see how excessive the voltage is when the vehicle is supplying ~14.
You must also realize that the voltage you measure will be higher when there is no load on it. In other words, you'll measure 13.8 until you connect the radio and that will cause it to drop. With regard to the scanner models you have listed, another factor is the batteries in the scanner. If they are in need of a charge, they will further drop the voltage down.
From my point of view here are the solutions to this issue:
- Purchase an adapter that has a regulated output (I'm not sure they even make them).
- Build your own adapter with a 9 volt regulated output with the required capacity (charge the batteries, operate the radio).
- Don't use a vehicle adapter.
My choice was the last one. I bought a couple sets of Eneloops NiMH AA batteries just to run my radios. Even with high volume and the display backlight on, they will run the radio for several hours. When they're dead, I switch to another set. I've set up means to separately charge the batteries in my vehicle for long trips, otherwise I just charge them at home. I also like the fact there's no extra wires to the scanner in the vehicle.
CarvinDude
After some research I agree with with you regarding the "don't use one" theory. I still have both of the battery holders. I'll probably just load up the rechargeable holder with regular alkalines for a quick swap if needed.
Thanks for the common sense solution.
tvengr
Well Known Member
Baltimore County, MD
I wouldn't use the rechargeable battery holder for alkalines. You have the chance of overheating the alkalines and damaging the radio.
CarvinDude
I planned to put a piece of tape over the charge contact on the yellow battery holder just in case I forget. The only time I use that port is at home with a well regulated ac adapter. Accidentally charging alkalines would definitely make a serious mess out of my radio. I'm not a rechargeable kinda guy.
Thanks much.
brcoz
Florence, AZ
I ordered:
Enercell; 9-Volt 1000mA Vehicle DC Adapter - Requires Adaptaplug Tip (sold separately) and Adaptaplug "C"
from Amazon for my pro106. Bought one for each car.
krokus
Southeastern Michigan
I ordered:
Are those regulated? If so I wll definitely check them out.
Thanks!
That is the RS house brand adapter, which works well. I have used one with my PSR-500.
brcoz
Florence, AZ
Adaptaplug "C"
  • Outside diameter: 4.7mm.
  • Inside diameter: 1.7mm
  • Yellow insulator has narrowed EIAJ-3 opening
