Radio signal fades while moving
Hutch7344
Hey guys not really a problem I’m having just something I noticed and now I’m curious about. If I’m sitting still it acts normal, static with the squelch off that gets progressively quieter as you turn the knob up. But from 30mph and up it’s almost silent even with no squelch, as soon as I slow back down the static and signal meter go back up to normal. I still hear talking just fine but I was just curious if this is normal behavior since I’m still new to the CB world.
ForestRunner98
917 SoCal
Maybe when moving wind resistance is bending the antenna back and your loosing signal. That shouldn’t happen. Check for something loose.
bharvey2
Do you hear any noise/interference with the radio's squelch on minimum and the engine on and at idle? The first thing that comes to mind is that your vehicle is creating interference, increasing as speed increases, and desensing your radio. If it's engine related, you may be able to recreate the problem by keeping the transmission in neutral and revving the engine. BTW, is this install in an electric or electric hybrid vehicle?
Hutch7344
It’s a 4ish foot mag whip mount on a Subaru. Doesn’t really seem to be interference, at least not engine. Revving the engine in neutral the radio doesn’t sound any different than it does at idle. Everything on the antenna is tight so I don’t think it’s moving around more than any other whip antenna does. Like I said I still hear talking and my radio checks always get answered, I just thought it was strange how the static goes away and the signal meter drops to near zero while driving.
