Would IPSC be the appropriate agency to contact for a state-owned radio tower where the tower lights do not work? I contacted the ISP PIO Facebook acct in early June, but as of yesterday the tower lights still did not work.
Just be aware it IS a holiday so your call might not get immediate attention.
Use the direct contact info I posted.
IPSC:
General inquiries: 317.234.1541
Network Operations Center: 317.234.1540
Radio Shop (Greenwood): 317.899.8571
Mailing Address:
100 N. Senate Avenue, N825
Indianapolis, IN 46204
Here in D 52, they do still do tower light checks regularly. I have also heard D 51, and D 53 doing them. Maybe due to Indy being a flight congested area with the KIND, and like three other airports, and Heliport downtown (Which may soon be moving over to occupy the former Diamond Chain facility), as well as multiple helipads at the TV stations and hospitals etc?
I totally agree. If our tower lights failed, we were required to contact the FAA immediately.The FAA has primary regulatory oversight.
Probably not back-ordered, TBH...when those guys climb towers they solve the problem usually that day - or they have a trove of ideas on how to solve the problem very quickly. Anything that is so rare that is backordered months would probably be phased out (by them) so they can get up & down and fixed in as little time as possible. Couple of times we worked with them they had a spare for everything, a plan for if the spare didn't work, and a contingency fix if the plan didn't work, as well as a plan B C & D.I'm hoping it's a backordered equipment issue, and not a breakdown of communication between ISP and IPSC from my June communication attempt, which would be ironic.
LOL yeah, system maintenance techs are almost as resourceful as the communications techs and Moto guys. And some of them do both.Probably not back-ordered, TBH...when those guys climb towers they solve the problem usually that day - or they have a trove of ideas on how to solve the problem very quickly. Anything that is so rare that is backordered months would probably be phased out (by them) so they can get up & down and fixed in as little time as possible. Couple of times we worked with them they had a spare for everything, a plan for if the spare didn't work, and a contingency fix if the plan didn't work, as well as a plan B C & D.
The tower has been there, with lights, for several decades. The tower is 419.9 feet tall. Towers over 200 feet require lights.It could also be that the tower initially had obstruction lighting installed but the tower didn't require them by law and after a study was done they discovered that the lights were not required, but were expensive to operate and maintain so after the study they were turned off. This happened as a radio station I did some work on that was sold. The STL tower was lit although it was shorter than the FAA minimum height for lighting and the new owner had them turned off and later disconnected from the power since folks kept turning them back on.
