Iceking007
- Joined
- Nov 15, 2018
- Messages
- 22
Hello,
I am trying to figure things out and the more I do the more everything seems a complicated. Everyone around here either mounts on the front fender next to the hood or uses a magnet on the roof.
With regards to a pickup truck installation:
Is a magnet bad because of electromagnetic interference?
Would the trade off so be worse than having it on the fender (vs the center of the roof we a magnet)?
I've been reading that the rule of thumb is 3' from other antennas and GPS receivers; that means even the roof might be not ideal, is the box going to be a viable option?
Additionally I am considering having a CB, VHF, AM/FM, plus most vehicles have GPS now, plus of you add your dash GPS, plus of I add a scanner in the future... how/where/what do you do with everything?
(I'm sorry I've just been very lost lately - in life in general)
I just found out that only the tip transmits the signal, is that the same for receiving?
If the tip contacts the ground plane (also read grinding system) does that create a dangerous short? (If so then I've just been extremely lucky! :::EEPS::: )
At this moment I'm considering mounting a small spring/quick release in the center of my roof for changing vhf tuned top mount antennas, then mounting my 10' whip CB antenna to the left rear corner of the box. The AM/FM is located in front of the passenger.
But I keep going back and forth if I want to drill holes in the roof.
Also, why do highway tractors mostly have all the antennas on the mirrors? If they get decent enough reception does this all really matter??
Also, what about Marine antennas. Perhaps this are fund to a different frequency range, but they look very well built. Could that be used on a truck for vhf?
