re: the dark knight drone dkd2 sdr scanner
steve-kc7byp
West Richland, WA
BM82557 I tried opening the FMP program and a CMD line box opened up with the following error message bellow in it. The cmd line window doesn't even stay open long enough to screen capture it. I had to capture the picture on my cell phone and hand transfer the text to Windows wordpad. I also am having a problem with the cell phone connection to the laptop. The USB driver is not setting up right. That is a different problem, not connected to the RTL dongles.
Steve
FMP rev 1.18
Usage: FMP WaveOutputDevice# SDRdevice#PPMcorrection Frequency
SDR sampling rate - 1.008 mhz
Spectrum window width - 512
FFT size: 32,768
Spectrum update rate: 10 hz
Step size table: 5.000 6.250
DSD+ path *.*
Primary Frequency list: '.\FMP-FreqList.csv'
Secondary Frequency list: '.\FMP-RRSystems.csv'
Database search distance:99.90 miles
Base latitude/longitude: 19.7163 -155.6241
Audio output device #1 = 'Headphones high definition Audio'
Audio output device #2 = 'Speakers high definition Audio'
Audio output device #3 = 'Line 2 <Virtual Audio Cable>'
Audio output device #4 = 'Line 1 <Virtual Audio Cable>'
Invalid WaveOut device number specified
Check your Windows folder where you installed DSDPlus in, the highlighted one in the screenshot is the FMP program -
BM82557
Berkeley Co WV
Steve
FMP rev 1.18
FFT size: 32,768
DSD+ path *.*
See number 5 here - http://forums.radioreference.com/vo...re/312886-dsd-plus-1-071-fmp.html#post2386527
Also info on the FMP program is in the FMP text file (see screenshot two posts above)
An example of what I use for my local system is FMP 4 2 28 452.8750
steve-kc7byp
West Richland, WA
BM82557 I read everything at http://forums.radioreference.com/vo...re/312886-dsd-plus-1-071-fmp.html#post2386527 I understand what has to go into the FMP shortcut target line. But I am not sure of the exact syntax of the target line. Also I don't know the PPM correction value for my dongle or how to find it. Again to me this type of SDR software is so new to me. it is like tiptoeing through an Alligator Farm full of sleeping alligators. ;)
slicerwizard
Toronto, Ontario
When you create a shortcut, it already has the correct drive/path/exename; you only need to append the four numbers:
- audio out device
- dongle number
- PPM
- MHz
Tune to a known active frequency (like NOAA); adjust PPM until you're centered. Easy peasy. Honest...
steve-kc7byp
West Richland, WA
So after the exe something like /50 45535? PPM is set at +50. There was a QSO on the local repeater. I used that to set the PPM. I am slowly getting the hang of these SDR dongles
- audio out device
- dongle number
- PPM
- MHz
