rebanding bcd325p2
kawika95
Having read and researched Rebanding, I have a bcd325p2 scanner. My scanner has the band plan and when i look at the frequencies it has a LCN - Logical Control Number) slot.
Since Charleston SC has gone to Reband, I would like to know the LCN for said area.
If anyone and or Uniden can assist, I would appreciate it much.
I do like to listen to Police chatter at night. It is interesting to do so. It establishes an insight as to how PD(s) operate past the thin veil of "polite society".
If Uniden and or others can assist me, please do.
My email is kwikaphn@outlook.com.
I do understand somewhat how a LCN works.
lower Freq upper freq step Offset
851.025 854.0000 25 440
851.0125 868.9874 25 0
Freqs lcn l/o vol adj tag
851.0375
851.6500
852.0375
853.2625
854.4875
854.9625
966.9625
The above is the data I have currently. I have upgraded to the newest firm war 1.08 firmware in. That was done well.
Again, can any one assist me or can Uniden supply the "missing data".
I thank you in advance
God Bless
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
If you're trying to copy this system
Then you don't need anything to do with the LCNs. What you need is a rebanding custom table that will be supplied automagically if you use any of the supported apps for that radio (FreeScan, ProScan, ARC-XT). It can be entered manually, altho it is a bit of a pain. See here...
A (cheap) premium subscription makes this task simple
Mike
tvengr
Well Known Member
Baltimore County, MD
With Motorola systems, ignore LCN's and you can enter the frequencies in any order. All you need is the custom 800 MHz rebanded band plan.
Band PlanBase Freq (lower)Base Freq (upper)OffsetPolaritySpacing
1851.025854.0000440+25 khz
2851.0125868.98750+25 khz
If you do not have the DMR or NXDN upgrades, all you need is FreeSCAN software for programming your scanner and it is FREE! Downloads - Sixspot Software. Using the software, you can use your premium subscription to download directly from the Radio Reference database.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
The OP is close to the truth - in fact, Moto systems do use a LCN in a calculation that helps determine the next available frequency. This calculation breaks down when rebanding is concerned, and that's what the custom table (which I see he has in his message) adjusts. It's just the mechanics of how to get the custom table into the radio that is different between the Unidens and GRE based scanners.
kawika95
[URL
I thank you for the information.
Do you know the LCN for the Charleston SC area and or Charleston Area in general?
I have used all methods to search it.
That must be "top secret" set of information.
Again, thank you for the information.
Mike
I have the table. I have previously stated the freqs. limits and offset. Yet, I can not receive. North Charleston SC is a complete blank.
tvengr
Well Known Member
If you download and install FreeSCAN, I will be able to check your programming for errors. Connect your computer to the scanner. Go to the Scanner tab in FreeSCAN and Download programming. Your programming will transfer from the scanner into FreeSCAN. Save the file. To be able to attach the file, you will need to right click on it and Send to Compressed (zipped) folder. Click on Attach files and Open the zipped folder. If scanner is unable to communicate with FreeSCAN, you may need to install the Uniden driver.
wtp
Port Charlotte FL
it looks like they are on the Palmetto 800 system.
and there are a number of towers to choose from
1 (1)009 (9)Charleston Simulcast (State)Charleston852.2625854.6375854.9875855.1375856.3375856.8375857.3375
857.8375857.9625a858.3375a858.7125a858.8375c859.6875859.8375
859.9625
1 (1)010 (A)Charleston Simulcast (County)Charleston851.350852.350a852.900853.5375856.2375856.4875856.7375
856.9375857.2375857.4875a857.7375857.9375a858.2375858.4875c
858.7375858.9375a859.2375859.4875859.7375859.9375860.2375
860.4875860.7375860.9375
1 (1)013 (D)North Charleston (Charleston County)Charleston851.100851.7125852.100852.675852.975853.200853.5125c
1 (1)058 (3A)AwendawCharleston856.3125857.3125858.3125859.3125a860.3125c
1 (1)059 (3B)RavenelCharleston851.325851.825c852.2125852.5375853.0375
kawika95
I have a BCD325p2 scanner.
I have and do get Dorchester, Berkely, SCHP, Interop, etc... Frequencies directly from Radio reference.
I get them clearly and do get the (also) the Common freqs.
But, Charleston County, North Charleston County and City of Charleston County have gone dark. (to include Mt. Pleasant SC)
I have the frequencies in my scanner. I do understand that. I do understand Control frequencies.
Being that Dorchester, Berkely, SCHP, Interop, etc... do receive well, I can say that I am missing some "setup" for the scanner to properly receive Charleston County, North Charleston, and City of Charleston (all SC) communications.
I do require assistance in receiving these transmissions.
Should anyone have any information on this subject, please contact me at kawikaphn@gmail.com. Please use the heading "Charleston scanner help".
Any other heading will get immediately deleted.
Please do so at your leisure.
God Bless.
Whiskey3JMC
Just another lowly hobbyist
Philly burbs 🇺🇸
Out of curiosity what's the point of posting on a public forum if you're asking for help via email? I'll give my input here since the purpose of posting on these forums is for others to chime in and maybe someone may learn something new:. Let's begin:
What specific agencies are you unable to pick up? Taking a look at the talkgroup tables here and focusing on the "mode" column, No scanner, no receiver will be able to pick up those talkgroups ID'ed as mode "DE". These talkgroups are fully encrypted. This includes law enforcement on all counties / cities you inquired about. So if you're looking to pick up police, you're out of luck. Every other talkgroup ID'ed as mode "D" CAN be picked up (fire, public works, others). Hope this addresses your question.
hiegtx
Dallas, TX
God Bless.
This is a repeat of your other thread from last week:
(One of the moderators has merged your new thread into the old one, which is where we are now.)
You were asked to upload your programming file so that someone could check for possible errors, but you did not respond after that:
There are a number of people on this site that might be able to help you, but for that to happen, you need to be responsive as to where you are at in the programming process.
From what I see on your county's database page, it appears that the agencies you are trying to hear may have moved to the statewide system, Palmetto 800, instead of the Charleston City Public Safety system that you are trying to receive.
For the Palmetto system, the two largest sites in your county are simulcast, which is not your 325P2's strong point.
Simulcast Distortion - The RadioReference Wiki
Also, the majority of the law enforcement talkgroups for the agencies in your county are encrypted. Your 325P2 would simply ignore those transmissions.
brian
DB Administrator
South Carolina
You aren't hearing law enforcement in Charleston County because all law enforcement radio transmissions are now encrypted.
All Charleston County radio traffic is carried on the four "Charleston (County)" sites - 1-10 Charleston Co Simulcast, 1-11 Edisto Island, 1-12 Summerville and 1-13 North Charleston. You must be monitoring one of these 4 sites to hear Charleston County agencies.
State agencies and other counties (such as Berkeley and Dorchester) are carried on the "State" sites - such as 1-9 Charleston Co Simulcast (State), 1-58 Awendaw, and 1-59 Ravenel. If you're monitoring one of these sites, you'll hear MUSC, SCHP, Berkeley and Dorchester Counties, medical helos, etc. but no Charleston County agencies.
As this is a APCO P-25 system, rebanding tables are NOT required. The bandplan for the system is carried over the control channel, and your scanner should use that bandplan to properly track the system. Do not manually set a band plan.
If you program one of the "Charleston County" sites that are in range from your location - 1-10, 1-11, 1-12 or 1-13 - and add any of the Fire or EMS dispatch talkgroups, you will hear their traffic, which will verify that you have programmed the system properly. If you monitor site 1-10, It will also give you an indication of how much simulcast distortion will be and issue for your scanner in your location.
But as for Charleston County law enforcement, unfortunately, you'll be out of luck.
