reception isues
RDCat
N.W.
i have a radio shack vhf-hi/uhf
what would be a good mounting application for a flat roof design
i'm having i thnk overload issues on vhf freq's,heing radio signals bleeding over
its a pro 2096-should i raise the antenna up higer,its placed at 30 ft right now
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Raising the antenna higher is likely to make your overloading problems worse.
I'd put on the attenuator - if things return to normal, then a filter (such as those sold by PAR electronics) is needed. I believe the 2096 (and the 2055 for that matter) are prone to overloading on VHF hi 73s Mike
RDCat
N.W.
ok
its seems like overloading? of 4-5 freqs at a time of bleed over of a radio station signal
i'm running simple coax from tatget 25 ft...
SAR923
Mike gave you the right answer. The Pro 96/296 is prone to front end desensing when attached to a relatively high outdoor antenna. The "bleedover" you're hearing is actually several stations mixing together on one frequency. The test is to punch in your weakest NWS weather channel. Hit the attenuator button. If the signal gets better, you've hit pay dirt. Here's what I've done to solve the problem:
1. Use the best coax you can. At least a good quality of RG-6 or LMR 400 helps.
2. Apply the attenuator to all VHF high band frequencies you have programmed. The desense seems to primarily affect signals between about 145 to 170 MHz. You should see an immediate improvement in the the signal mixing problem without losing any range.
3. If you are in an urban area or live within sight of a cell phone tower or commercial radio tower, you may need an additional filter. You can buy them from places like PAR Electronics or a number of other on-line sources. I use a combination FM notch filter and 30 MHz high pass filter. The model number is HPN-30118 and I think I got it from Universal Radio. PAR generally has a better selection of filters and they have a good reputation but the price is also higher and this filter has done the job for me.
I have my Pro-96 hooked up to a Radio Shack 20-176 ground plane mounted in the attic, which puts it about 20 feet about the ground. I have a pre-amp attached to the antenna right at the antenna connection with the RG-6 coax running down the walls to the radio in my den. The filter has BNC connectors and sits on top of the 96, one end attached to the radio and the other attached to the termination of the coax. All my VHF-hi frequencies are attenuated. I can regularly hear counties on VHF in the area around Atlanta, which is about 115 air miles from me. I rarely have any signal mixing or bleedover problems.
If you take the steps I've outlined, I think you'll be quite pleased with the results
RDCat
N.W.
ok ill look into att on all vhf freqs...........and better rg6 coax
RDCat
N.W.
ATT helps a bunch
but i have a bunch of vhf reception i listen too
800 works good
and the state dtrs works ok
i might ditch the thought of the roof ant.
just use the issued 2096 ant!
SAR923
The attenuator should not actually degrade VHF reception compared to the standard rubber antenna. Test this on the weather frequencies. If you can hear a frequency with the roof antenna even though it's attenuated better than with the standard rubber antenna, you're still better off with the roof antenna. It's not difficult to apply to the attenuator to all VHF cheannels. especially if you are using a computer program like Win96. Even by hand, it wouldn't take more than 10 minutes.
RDCat
N.W.
yes ive added ATT to my long list of vhf
seems ok right now some fuzzy reception on certain channels
