One item that I haven't seen mentioned here is that there is a version of the AB-155 mast that has 2 pivoting mast stubs on the stake.
What is truly marvelous about these is they allow you to use a half height mast from another kit or spare mast sections as a falling derrick. You measure all of the guys that will hold up the side of the mast being raised to one of the other guy stakes, tie the guy lines and a pull down rope to the tip of the falling derrick, raise the falling derrick up and drop it onto the second pivoting mast section stub, pull the falling derrick down until the mast is straight up; a surveyor's rod level is really helpful for getting the mast plumb; If you have set the length of the three other guy directions carefully then they will be close to the correct length and not require much adjustment. The 20 foot length of the falling derrick provides a much better angle of effort on the mast itself. There is no need to walk the mast up to get raising started. The pull on the guy lines by the tip of the falling derrick does much of the work. This technique also reduces the number of persons needed to raise the mast to 2.
Although I would not recommend this as a routine practice I have been able to raise the full 40 feet of mast with a whip adapter and 15 feet of MS-116 antenna whip on it and the insulating section scavenged from AB-86 mast kits at the base. By removing any aluminum oxide from the outside of the swages and the inside of the mast section bases using wire brushes or emery cloth and then applying a light coating of Anti-OX, Noalox, or Ox-Gard conductive aluminum anti oxidizing paste to the mast section joints you turn the mast into a very effective vertical antenna. When used with a remote automatic antenna coupler at the base of the mast and 4 above ground radials from the ground connector of the antenna coupler the mast will cover 160 to 6 meters very well. We have used that assembly repeatedly for field exercises and outdoor events with great results.
Tom Horne
