Regency HX-650
scanman75
ohio
I have an old Regency handlheld, HX-650, trying to locate an AC adapter that will work with it. It seems to use a connection that is similar to a headphone Jack.
rk911
Rich
Wheaton, IL
ok...6vdc. the minumum amps required is missing but a 6vdc cube with at least 2-amps should be good. OP....now do a google search for a 6-volt AC adapter. photos should tell you if the connector is correct. good luck.
rk911
Rich
Wheaton, IL
2 Amps seems more than necessary, but as long as it is a regulated output, it should be fine
just a guess since that spec is not listed. the point is to not use a brick that produces less current than the radio requires. the owner's manual may have the complete specs.
