Repeater on Itinerant Frequency?
b7spectra
EMS Dispatcher
Cobb County, GA
Came across someone in the Metro Atlanta area with a repeater up on 464.5500 MHz. I confirmed it was a repeater by programming it into my radio and, don't get mad (SAPS, you know who I am talking about) kerchunked it! I thought allitinerant frequencies were limited to portables. :confused:
N4DES
Retired 0598 Czar ÆS Ø
South FL
I did some reasearch for someone not to long ago for someone and from what I found, if I read the rules correctly, no repeaters are allowed there for general category use. There is a PS pool that allows for temorary usage and has to be coordinated/licensed.
ecps92
Taxachusetts
464.5000 & 464.5500 can be used as Repeaters or Simplex.
+5 Mhz for the inputs.
The licenses are typically FB2I [Itinerant - not a Perm Location]
ULS License - Industrial/Business Pool, Conventional License - WNWR931 - DUNN JR, WILLIAM E - Frequencies Summary
b7spectra
EMS Dispatcher
Cobb County, GA
The Cornelia station is too far away from here. I hit the repeater from inside my house on a 4 watt radio, so it must be near by, but nothing in the FCC DB. Makes me wonder if someone got bamboozled by a rouge radio installer.
BTW, they are also on a DCS of 703 input/output. I think I'm going to try and track this one down!
ecps92
Taxachusetts
If you are using the FCC Search, remember, many license these for "Nationwide Use" and you will only find the license under the Home [Mailing Address] State.
