Hi, I need to reset a ws1065 to factory setting. can someone help me with this? Thank you
From page 53 of the WS1065 owner's manual....
press each sequence while the scanner displays the Welcome/Owner screen..... (you must press the 0 key while the Welcome screen is showing at boot-up.... if you miss it, it won't work.)
0 key, followed by the 1 key
Destructive, clears working memory and resets all global parameters to fatory defaults. Does not affect V-Scanners
