It's just 20 years old but very serviceable!
Hi all. I'm setting up an older kenwood TM-733 with aprs with a Nuvi 350 which I believe can be used to txt message, well that's the plan. I think byonics trak4 won't support this function and the argent OT2 is, well, rare. The plan is to use (mostly find) a OT2m, because I need the dual DB9 for GPS and Radio. I have the radio and the nuvi 350 and all the cables I believe, (hoping the pinout is good).
Any other options out there for this setup? I don't know a lot about TNC controllers manufacturers out there. Maybe Microsat? I still need an option to connect the TNC to the kenwood with some sort of PG-5A adaptor. Not sure if I require the RJ45 for aprs in this setup.
So questions are:
1-Any TNC compatible with nuvi 350 / tm-733 ( with garmin protocol for txt messaging ) ?
2-Cables assembly recommendation depending on answer to 1 ?
3-Do I need the RJ45 mic to run the aprs or the pg-5a will do ?
4-Will I keep the mic usable while aprs'ing ?
5-Can I crossband this setup somehow with my HT that have aprs ? ( that will come later and is a bonus )
I hope I made sense because it's a tad technical and I'm hardly keeping tabs on all this.
73 to all!
recycle for the planet.
So questions are:
73 to all!
