- Joined
- Sep 4, 2020
- Messages
- 63
I have a bunch of rg6 coax and was wondering if it is acceptable for use in VHF and HF applications. Thanks
4 feet? If you mean four feet then the difference is moot. Use wet string or whatever you have laying aroundAbout 4 feet, jut from outside to inside.
Right out the window to the mount.A four foot run from the antenna to the radio...be still my heart!
At 700MHz RG8X has twice the loss over RG6 at 100 feet. Don't use RG8X.When I bought a gen-u-ine Ed Fong TBJ-1 (tri-band) antenna, Ed graciously called me a week later to see how I liked it. We talked about coax for a few minutes and the gist was this: Up to 50 feet, you can use RG8x. At 50 feet or more, use LMR400. For just 2-6 feet you could most likely get away with RG6, but more than that, you're better using the above. Yes, LM400 is very expensive, but RG8x is quite affordable. If you're going for a long run, just go for the good stuff. It'll only hurt a minute. The first week you transmit with it, if you have a good antenna, you'll be glad you splurged.
That will be fine!About 4 feet, jut from outside to inside.
There's nothing wrong with RG6 but you may need to use either a matching pad or a transformer depending on your situation.
75 ohms is better for low-power/receive loss anyway, with 50-60 ohms being a compromise between that and 25-30 ohms which is best for power transfer...understanding the performance of coaxial cables is not terribly simple in general but is quite useful.
In short, give the RG6 a go, you have a short run so the losses will be negligible except for mismatch loss which itself isn't enormous.
