kmacka
My two Diamond RH&&CA antennas arrived today from www.hamcity.com. So I wanted to test them out and compare them to my stock antennas. Well I am very happy with the RH77CA's, they definately perform better than the stock rubber duckies. Now I had the rh77ca on my pro-97 and was hearing KAVP atis pretty good from my location in Scranton, PA, I would not be able to hear that with my rubber duckie. Ok then I connected my gre super amp to the scanner and then attached my rh77ca to that and then again tuned into KAVP atis. Well when I turned on the amp, I wouldnt be able to hear the atis, then when I turned the amp off/bypass, I would be able to hear it clear again. I even adjusted gain, to no avail. Now then I took the amp totally of the scanner and attached the antenna and then again, I can hear the atis pretty good. Now I don't know if this amp and rh77ca is a good combination, obviously not.
I'm hoping someone could give me some ideas why this isn't work correctly and was is causing it. Also if anyone else has any suggestions on how to pull in more signals or boost signals, if anything. I was also thinking about getting that Maldol antenna designed for the civil and milair air bands.
