Analog simulcast is less of a problem than P25, but the Richmond area system is a P16 system that uses digital voice. These systems use precise timing schemes to reduce the effects of the signalling from multiple tower sites arriving at the receiver at slightly different times, and are optimized for receiving from within the the system's intended service area. Higher quality public safety grade receivers obviously do better than consumer grade scanners. My GRE PSR 800 (upgraded with Whistler 1080 firmware) does an OK job on our local P16 SmartZone system on the fire side (which is analog,) but is very sensitive to location when monitoring the police side, which is digital. But even the analog signalling gets wonky (fading / staticy audio vs. digital breakup) when monitoring from an area where several tower sites are providing coverage. My 436 also had issues with the P16 systems, but the 536 and the SDS radios did better. People seem to like their TRXs, but I'm not sure if they are much of an improvement over the PSR800 / WS1080s wrt P16 digital reception.
