Right Angle PowerPoles
N9JIG
Sheriff
Moderator
Far NW Valley
I am in need of some right-angle PowerPole connectors or even adapters. Here is my dilemma:
I have a WestMountain Radio "PwrCheck" (shown below) that I want to mount on a panel. In order to accommodate the power leads that come out the right and left I would drill holes in that panel. For aesthetics sake I would like to install right-angle PowerPoles to dress the wires straight back and thus the holes would be closer together.
I could use a different style meter or a power supply with integrated meters but I already have the Astron and this PwrCheck as well as a panel to mount it on. Right-Angle connectors would be a decent way to dress the wires in my system should they be available.
I have checked all the usual sources but so far no go. I have gone so far as to disassemble the PwrCheck to see if it is worthwhile to remove the connectors and solder leads and that is a solution I am seriously considering.
n1ofj
Money is better spent on equipment that protects equipment from low/high voltage. Fuses exist to protect from over current situations and addresses it immediately. What exactly does this device do to protect equipment? This device looks like window dressing.
slowmover
Fort Worth
A monitor
FWIW, I’ve had to re-organize radio gear on how to use devices such as RigRunner to accommodate runs.
I joke that these carriers are my erector set radio shack. It rides in the passenger seat, true; it makes for easy vehicle removal, true; it provides a much easier way to install accessory componentry, also true.
By the pic, I’m not seeing the dilemma. I might “case” the monitor and have the APP terminated power leads run thru that (wide enclosure approach).
The TRC makes this easier for me. PwrChk would be a sub-assembly component of its own mounted on or in the TRC.
A marine power distribution panel is otherwise what comes to mind as model:
Pegboard is a tried & true approach.
“Radio shack” aboard a tool cart would be handy.
Keep the power leads long enough and can roll to throne room for QSO when conditions are hot.
