RPM COMM Port issue
petty4305
Georgia
I have noticed that recently in RPM when I try to push a personality I get a window shown below.......
I tried to repair and reinstall RPM with no luck. It also tries to say that the COMM Port is in use or invalid, but the port is working perfectly in device manager.
Can someone shed some knowledge on this. I'm stumped......
petty4305
Georgia
Never seen anything like that before! Is the com port set to a weird baud rate something?
-B
I don't see anything out of the ordinary. And the weird thing is that the USB-Serial cord works fine in RPM 2 and the same cord works fine on RPM off of my Surface Pro laptop. It just doesn't like RPM on my Toughbook.
BMDaug
I am licensed…
Central Colorado, USA
Same computer using rpm2 works but not rpm14? Or are these different computers?
-B
petty4305
Georgia
-B
I think I might have figured it out. I looked at the comm port settings on the surface pro with the cable plugged in and just mirrored them for the toughbook. It seemed to work. I guess sometimes you just have to talk it out. Thanks for listening.
Forts
Ontario, Canada
Has anyone else come across this? I had to format my laptop... Just re-installed RPM R14C and RPM2 and both of them are giving me this same error. I've no idea how to get around this. The port is working fine (it's a USB-Serial). I can plug into a radio using Putty and talk to it no problem, but RPM does not like the USB-Serial for some reason. Aggh! It's always something it seems when you have to reload all your stuff.
KA2FWN
central ny
C:\ProgramData\Harris\RPM
edit the radpersmgr.xml file , change the port to the one you need.
PortNumber="1"
you cant change port in rpm but it still works
KD2DXF
Nobody
Anytown, USA
I had the same issue. Spent 3 days trying to figure it out. Issue turned out to be the laptop wifi. If your using a serial connection, turn off your laptops wifi.
