BillQuinn said:
Should i get a 13.2 v battery pack for it?
From what I have seen, the stock 7.2v battery will give 2.5 watts output and the AA pack will give 4 watts (with 9v) so you can see that the 12v & 13.2v packs will give even more power from the battery.
This place sells many batteries for the 202 at several voltages.
http://www.batteriesamerica.com/radio_shack.htm
BillQuinn said:
I heard about and ERROR 2 display with a 13.2V battery.
ER2
LL UNLOCK ERROR
Er2 indicates the transceiver's PPL section has unlocked. Have the
transceiver repaired by an authorized Radio Shack service center.
This radio is likely to get an ERR2 when running off a cigarette lighter.
This is due to RF feedback which travels from radio to rubber duck to
power cord and back to radio. The best way to fix the ERR2 is to use an external antenna.
You can download a PDF of the manual here...
http://download.qrz.ru/pub/hamradio/schemes/transceivers/HTX-202-1.pdf
Good info at...
http://www.icanworkthisthing.com/docs/amateur_radio/handheld/HTX202 and Notes.shtml
http://www.icanworkthisthing.com/docs/amateur_radio/handheld/HTX202 PL guide.shtml
http://www.icanworkthisthing.com/docs/amateur_radio/handheld/HTX202 cheat sheet.shtml
http://www.qsl.net/wb3gck/htx-202_err1.htm
....and we all love rigpix as well....
http://www.rigpix.com/rs-realistic/htx202.htm
roadranger said:
According to direction, a simple reset funtion can be preformed. It takes about four fingers and co-operation of both hands and feet, but it can be done. If you want it, I can find the reset intructions, but it won't be long before you'll need a memory-backup, Lithium battery.
You're thinking of the ER1 :wink:
Er1: INTERNAL RAM ERROR
Er1 indicates the transceiver has detected an error in its battery-backed up operation memory. This is the most commonly caused by a low lithium backup battery, but can also be caused by static discharge, or a physical shock. To clear the error--
1. Turn off the unit.
2. Press FUNCTION and CLR (the D key).
3. While holding these keys, turn unit on.
This will reset unit and clear memories.
If the transceiver frequently displays the error, have the battery replaced by an authorized Radio Shack service center.
