RSS Spectra
Muxlow
Super Secret
Middlesex County
I have version R06005.
How do i creat a codeplug for a 800mhz spectra to work on type 2 systems and a few conven feq's?
Havnt been able to figure out how to creat one.
Perhaps im to use to macoms "programmer"
model number is
D45ZXA5JC7AK
N4DES
Retired 0598 Czar ÆS Ø
South FL
You can't "create" a codeplug. You must first read the radio and then you are limited to the features that the specific radio has. If the radio doesn't have trunking capabilities pre-programmed into the firmware there is no way to program trunking into it.
Other items include the need for the "system key" that is unique to each trunking system and is a must have as well as an ID assigned by the system administrator. Illegally programming to a trunked system can put others at risk and you stand the chance of having your radio inhibited by the system.
M/A Com equipment will not work on /\/\ radios.
Astro25
Chicagoland
You can often use lab to force in older codeplugs - read up more about it on batlabs.com >model specific info>spectra.
exkalibur
York, Ontario
That is, unless you want to pay Motorola an assload of money to make a custom codeplug and MLM for you.
Muxlow
Super Secret
Middlesex County
Iv been reading on that site alot.
Guess i'll have to wait untill my rib box comes in then make a cable for it and see what it has.
It already has some mutual aid thing programmed in it on a type 2 system. So it must have trunking
