SAFE-T and c-ch output on bcd396xt?
del1964
Southern, IN
Is it possible and if it is, what if any software is available to decode the c-ch output on a Indiana SAFE-T Motorola Type II 3600 baud Omnilink system that uses P25 digital talkgroups? Experimenting with the bcd396xt scanner and it's ability to output the control channel data stream.
DaveIN
Founders Curmudgen
West Michigan
Yes, you can. Did you get the information you needed from the PM's I sent you?
del1964
Southern, IN
Yes DaveIN, I finally got it figured out thanks to your awesome help. Uni-trunker worked great. I was just not going to give up until I got it figured out. Really neat seeing all that activity. Saw a bunch of "ENC" (encrypted I assume) communications going on and apparently more frequencies on that Seymour, IN site than radioreference database said there was.
