Saline County
t_murray
I can't pick up saline county sheriff. Has anyone gotten it to work yet. I have the bcd996p2 and programmed using Proscan and radioreference database.
tvengr
Well Known Member
Baltimore County, MD
Do you have the DMR upgrade for your scanner? The database shows the sheriff using both analog and DMR:
Saline County​
FrequencyLicenseTypeToneAlpha TagDescriptionModeTag
460.225WPEM677BM172 DPLSaline SO DispSheriff DispatchFMNLaw Dispatch
460.425WQEH591RMCC 1
TG 1000
SL 2
Saline Co LECounty Law EnforcementDMRLaw Dispatch
t_murray
Yes I have the dmr upgrade. Every once in awhile it picks something up but it's all jumbled and can't understand what they are saying.
tvengr
Well Known Member
It could possibly be encrypted. If it is, the Mode should show DMRE in the database, but maybe it has not been updated. Try setting it up as a conventional frequency, audio type Digital Only, code option Search. That will eliminate any chance of a programming error in the database. You should see color code 1 when receiving a transmission. If it is encrypted, you will hear unintelligible audio. Hopefully, one of the locals will jump in. I am just a little too far away to check it myself.
