Not much chatter on ther Diamond D707E. Pricey I must say.
So how about this antenna? Price I could deal with, approx. $54.84 - United Kingdom
Vertical Base Antenna
The Scanbase 1300 is a high quality, wideband fibreglass base station antenna for the scanner user. Features Chelcom Aerials unique helix/multi-trap system, to provide excellent reception over a wide frequency range.
The Scanbase 1300 is housed in a 19mm diameter fibreglass tube, with a heavily plated brass boss assembly, and stainless steel radials. The mounting tube is heavily anodised aluminium. Built to commercial standards, the Scanbase 1300 will provide years of trouble free, high performance reception.
Supplied with extruded aluminium mounting brackets, “V” bolts, nuts and washers. Will fit mast sizes up to 63mm diameter.
Marine
Civil Aircraft
Military aircraft
PMR
900MHz Band
Plus other public services
Frequency: 25-1300MHz
Termination: 'N' type
Length: 1100 mm.
http://www.chelcom.com/Aerials/scanbase.htm
Marine
Civil Aircraft
Military aircraft
PMR
900MHz Band
Length: 1100 mm.
