scanner antenna question
MB2010
Indiana
Im fairly new with communications and radios so please bear with me. I recently got a radio shack Pro-106 scanner. I have a maxrad MLPV800 low profile antenna, will this work with my scanner? I plan on mounting the antenna to my trunk lid via drilling and making it a permant mount.
gewecke
Banned
Illinois
Yes,but be aware that will not receive well on ALL bands but primarily should do very well on 700-1000mhz. So if you have any interest in vhf you'll hear very little unless it's close,and maybe a bit better on uhf.
73's.
n9zas
MB2010
Indiana
thank you for the help. I do know most departments around here are all on 800mhz so that was what i was looking for.
MB2010
Indiana
also another quick question, my antenna base takes a 3/4 inch hole. would it be safe to use a 3/4 hole saw if i take it slow and easy?
W2NJS
Washington DC
To be on the safe and conservative side, if you're not experienced with the hole saw the better choice is to use a Greenlee 3/4 inch round punch, but to do so you need good, clear access to the underside of the surface that you're cutting.
MB2010
Indiana
thank you for the advise are these cut out tools exspensive? I was leaning towards a hole saw because im on a limited budget.
W2NJS
Washington DC
Cutting holes...
The Greenlee punch may cost somewhat more than a hole saw but it's a tradeoff between the chance you take with a hole saw (especially if you're new at it) and the certainty you get with the punch. I haven't priced a Greenlee at retail in years but they were never cheap. First one I had was one I shared with two other hams when we were kids, a 1&1/8 inch unit to cut holes in radio chassis for tube sockets. I found my 3/4 inch unit on eBay and I think I paid something like seven bucks for it about five years ago. If you search Greenlee on eBay you might come up with the one you need.
DickH
Any hole saws I've used had a pilot drill. That should prevent it from "wandering", if that's your concern.
RickS31
Sunrise FL
Actually for professional metal drilling, the metal step drill bits are the recommended means to pop very accurate and very clean holes in sheet metal.
This is what it looks like and they are available at places like Home Depot, Ace Hdw., etc., etc. Cheaper and much easier to use than both a hole saw or a Greenlee puts in.
With it's step sizes, you can use it for all kinds of metal working applications.
The one here for example is a 12 step bit starting at 3/16" and going by 1/16" sizes up to 7/8"
