mikesatter
Member - K4AFT
Has SCHP Troop 3 moved from P25 phase 1?
I was receiving them but now I don't pick up anything from them.Back in 2017. The state merged into P25 phase 1. The SCDPS SCHP all troops moved to P25 phase 1
Radio Shack Pro-197 which is phase 1What scanner you using
It was working fine then slowed down receiving SCHP and now it does not receive them at all.I don't know anything about radio shack pro scanners. I use Uniden
My bad Central is Lauren's County right?Can you pick anybody else up on the Palmetto 800? Could be your Site you connecting to . Are you connected to Pickens county simulcast? Sometimes anderson county and pickens county is bad on hearing schp. Ill trying connecting to a different simulcast site. Did firmware updates?
Firm ware is up todate and was working great then basically quit working.Can you pick anybody else up on the Palmetto 800? Could be your Site you connecting to . Are you connected to Pickens county simulcast? Sometimes anderson county and pickens county is bad on hearing schp. Ill trying connecting to a different simulcast site. Did firmware updates?
Central is in Pickens County and boarder with Anderson County, and I have been receiving off tower 062 in Anderson County.My bad Central is Lauren's County right?
The same thing happened to me on my whistler 1065 awhile back. It would recognize a transmission but couldn’t hear no voice. I think they upgraded the voice on the palmetto 800 and my 1065 won’t decode it because it will still do Georgia P25 with no problem. Hope this helps.Has SCHP Troop 3 moved from P25 phase 1?
SCHP and Anderson County uses the same tower.The same thing happened to me on my whistler 1065 awhile back. It would recognize a transmission but couldn’t hear no voice. I think they upgraded the voice on the palmetto 800 and my 1065 won’t decode it because it will still do Georgia P25 with no problem. Hope this helps.
I have all the Palmetto 800 trunking system info but SCHP quit working on my radio.Here is the SC Troop 3 Palmetto 800 Trunking System, Various, Multi-State - Scanner Frequencies Talk Groups
Are you receiving Anderson, Oconee, and Pickens?They are working on my Scanner.
