Screen going blank
KO4IPV
Running a SDS100 in battery mode after 35/42 seconds my screen goes blank almost like a computer screen saver I hit menu and it pops back up how do I control this ?
Whiskey3JMC
Resident Numbskull
Simulcastylvania, TE
Keeping the backlight lit on the SDS100 would drain the battery a lot quicker. Take a look at the LCD & keypad backlight options here
KO4IPV
Thank you very much for your help I have gotten it all straightened out it was a simple simple fix just overlooked a certain area of the settings
jtwalker
Gettysburg, PA & Fenwick Island, DE
And just a point, you did this on the scanner so you need to "read from scanner" in Sentinel so these settings will get imported into Sentinel not get overwritten next time you "write to scanner".
