Good evening. This is not a performance issue, more of a curiosity. AirSpy mini running SDR# with Frequency Scanner plugin. Active Channel Spectrum activated. Nearly every VHF air channel is slightly off center from the peak signal. Reception is fine, just wonder why its off center (from the blue line), or is this just the way it displays. I have tried "lock carrier" setting both on and off. I haven't noticed this on other bands as traffic is light tonight. If it makes any difference, as you can see, channels have been programmed into Frequency Manager.
