SDR sending alpha tags?
Enforcer52
Lake Livingston, TX
I realize some scanners are not capable of transmitting Alpha Tags, but was wondering if all the newer SDR's had the capability since I am not that familiar with the SDR specs.
dave3825
Suffolk County NY
In general, one can not really compare scanners to sdrs. Scanners get programmed with all the alpha tag data and can display that on its screen, and also pass that to streaming software.
Sdr is nothing more than a receiver that relies on compatible software that has the functionality to stream, but alpha tag data gets programmed / imported into the software since you do not program sdr devices like you do a scanner.
belvdr
No longer interested in living
To add to the above, an SDR cannot transmit.
Enforcer52
Lake Livingston, TX
Oh come on, you know those are SDR-based transceivers. Normally when someone compares a scanner and an SDR, or mentions an SDR by itself, it is a fair bet they are talking receivers, not transceivers.
I specifically asked about transmitting alpha tags and if sdr's had the capability.
Enforcer52
Lake Livingston, TX
I mentioned scanners because of the new Beta WebPlayer. I understood older scanners may not have the capability to send alpha tags, but not being familiar with SDR all that much, I was wondering why some feeds that I knew were SDR were showing tags and others were not. So now I know that the software makes all the difference.
The ability to see the alpha tags with the Beta WebPlayer is a HUGH improvement when watching feeds in areas with multiple jurisdictions especially if you are not familiar with the area.
Again thanks to all for getting me straight on this matter.
belvdr
So when you say transmit, you mean to a streaming provider like Broadcastify, not RF. Some scanners, like the SDS200, can deliver the alpha tag data over its Ethernet port using software like RadioFeed or ProScan. SDRtrunk is an example of software that can do the same with an SDR.
