SDR Software to log traffic by time/length
tweiss3
Is it time for Coffee?
Ohio
So, I'm trying to get utilization statistics for our club repeater. I do have the repeater streaming to Broadcastify already on a RPi4 using RTL-Airband, but the only way to see traffic is to go through the archives, which is very tedious to click the file for every half hour of the day, plus it removes dead air, and I can't tell where in that 30 minute period it was used. I have a spare SDR dongle sitting here, and was wondering if there was a program (either linux or Windows) that could monitor and log each transmission it picks up. I don't need it recorded, just looking to compile a months statistics without setting something up at the repeater site.
rabbit108
S.E. VA
morfis
Whislt possibly overkill for what you want (I don't actually understand what it is you want) I will throw an idea in the pot:
sdrsharp with frequency scanner plugin can give a nice activity log (ignore the odd labelling in this, I edited out some text):
8:54:39 AM ; 239.225 MHz ; ; 5.5 secs​
8:54:45 AM ; 240.000 MHz ; ; 1.4 secs​
8:54:47 AM ; 242.675 MHz ; Airband - Military - ; 1.6 secs​
8:54:48 AM ; 244.600 MHz ; ; 0.7 secs​
8:54:50 AM ; 246.900 MHz ; ; 0.7 secs​
8:54:50 AM ; 250.000 MHz ; ; 0.8 secs​
8:54:51 AM ; 251.225 MHz ; ; 9.8 secs​
8:55:05 AM ; 343.700 MHz ; ; 1.2 secs​
8:55:09 AM ; 382.450 MHz ; ; 1.2 secs​
8:55:47 AM ; 269.475 MHz ; Airband - Military - ; 48.6 secs​
9:00:01 AM ; 290.975 MHz ; Airband - Military - ; 0.9 secs​
9:00:25 AM ; 290.975 MHz ; Airband - Military - ; 2.4 secs​
9:00:35 AM ; 377.900 MHz ; Airband - Military - ; 3.9 secs​
9:01:24 AM ; 377.900 MHz ; Airband - Military - ; 3.3 secs​
9:01:41 AM ; 377.900 MHz ; Airband - Military - ; 2.4 secs​
9:02:18 AM ; 377.900 MHz ; Airband - Military - ; 1.8 secs​
9:02:26 AM ; 377.900 MHz ; Airband - Military - ; 4.7 secs​
9:04:08 AM ; 377.900 MHz ; Airband - Military - ; 0.7 secs​
9:07:26 AM ; 233.350 MHz ; ; 2.1 secs​
9:08:55 AM ; 285.575 MHz ; ; 0.6 secs​
9:09:05 AM ; 297.575 MHz ; ; 5.1 secs​
9:13:46 AM ; 316.400 MHz ; ; 0.6 secs​
9:14:22 AM ; 377.900 MHz ; Airband - Military - ; 6.1 secs​
9:15:34 AM ; 377.900 MHz ; Airband - Military - ; 9.9 secs​
9:16:52 AM ; 377.900 MHz ; Airband - Military - ; 2.3 secs​
9:17:03 AM ; 269.475 MHz ; Airband - Military - ; 1.4 secs​
9:17:24 AM ; 377.900 MHz ; Airband - Military - ; 1.1 secs​
9:20:34 AM ; 346.550 MHz ; ; 3.2 secs​
9:22:43 AM ; 233.350 MHz ; ; 1.1 secs​
9:23:24 AM ; 256.025 MHz ; ; 0.7 secs​
So you have the time, freq and duration in a csv output. If you do happen to be using a recorder plugin you can have it record the audio traffic.
Someone says there was some abusive language last friday at 05:32 you can quickly and easily find out IF the repeater was active and pull up the audio to check. Easy to do analysis of when the repeater is most used and all sorts of other fun math (one of the only occasions that American seems more sensible than English - where it would be 'maths')
Whilst doing this it also creates a session log of hits on each active frequency.
I realise you are talking about a single frequency but you could set the scan to two frequencies - the one you want and one that is easily squelched out and that way you'll only ever see the stuff you wanted.
tweiss3
Ohio
That's not bad, but not cheap. I'd have to go with the Rational Waves version.
Have you experimented with enabling logging in RTLSDR-Airband? Link to the wiki entry on logging: szpajder/RTLSDR-Airband
I do currently have RTLSDR-Airband going, but I missed enabling the log. I will give that a shot.
I will look into that plugin. That's pretty much what I'm looking for.
morfis
Should have added a screenshot of the log config panel as other items can be logged/not logged and relevant to your use requirement
tweiss3
Ohio
I got what I needed internally with RTLSDR-Airband, I missed a whole section of the documentation.
Thanks for all the ideas guys.
