Anyone experiencing issues getting SDR Trunk to import certain systems from the RR database? NC Viper pulls up fine but Charlotte UASI will not import for me.
You might try the nightly and see if it does the same. Of course, backup your data beforehand.Not sure about the OP version but the issue can be seen in 060 beta 5.
0.5.3@DSheirer made some updates based on a bug exploring county systems. It may be related.
What version of sdrtrunk are you using?
Download Nightly Software Build
The nightly release contains current builds of the software for all supported operating systems. This version of the software may contain bugs and may not run correctly. However, it let's you preview the most recent changes and fixes before the next software release. Always backup your playlist(s) before you use the nightly builds. Note: the nightly release is updated each time code changes are committed to the code base, so it's not really 'nightly' as much as it is 'current'.
Thank you!There's a new 'TEMP' site that's been added to UASI that has a county ID value of 99,999 and that's causing an error in the sdrtrunk radio reference editor.
I suspect that county ID 99999 is an undocumented placeholder indicating 'County Unknown' and sdrtrunk is failing on this. I sent an email to the support folks to ask the question.
Denny
