SDRSharp not opening
dave3825
Suffolk County NY
I can't even open SDR#. Something isn't adding up.
Sdr will open even when an sdr is not connected so its not the dongle. 1920 opens fine without any dongles attached.
I may try a reload of Windows 10, but man, I have things set nice outside of SDRSharp.....
I would hold off on that.
If it were me, which its not, I would right click the unknown device, choose delete with remove driver, and refresh device manager and see if that fixes itself.
Open Sharp it stop loading on Frequency Manager, close on the task bar with right button, open again, its stop on Scanner Metrics plug In, close again on task bar, Sharp loading normally after closing second time.
Weird?
If the freq manager you have compatible with the version of sdr@ your using?
Kiniutech
Past login as: questnz
Somwhere in the South Pacific
I am using Community Plugins Package 1920, didn't change anything, will wait until updated version 1921 is ready
dave3825
Suffolk County NY
And what happens if you try the standard version of 1920?
SDR Software Download​
Software Defined Radio Package (Change log)​
This package contains:
  • SDR# (SDRSharp) revision 1920 (2024-04-25) – The BEST free SDR software for Airspy!
  • Airspy SDR drivers
  • AOR IQ drivers (AR5700D, AR2300IQ, AR5001D with IQ5001 option, AR6000 with IQ5001 option)
  • RFSPACE SDR drivers (SDR-IQ, Net-SDR, SDR-IP, CloudSDR)
  • HackRF driver
  • RTL-SDR driver installation script (RTL-SDR Blog Build)
Download
Kiniutech
Hi, just installed. Unzip to desktop folder, run setup, run Zadig, opening normally!
I only need scanning plug ins, will install manually to Plug Ins folder
I may check Community Plugins edition again
UTE-GE
Hi all, been busy so haven't checked in.
Sdrsharp, newest version has been loaded for a few months and worked like a champ. Everything was 100%. I tried to open it this past Sunday and it would just simply disappear. I un-installed and reloaded with no effect. As I type this I am reinstalling W10.
Will report later if it (SDRsharp) works or not.
What a pain....
Kiniutech
What a pain....
Hi, don't just reinstall Windows anytime SDRsharp goes wild!
Seems to be too much work
You may try other things, eg. system restore to some previous stable date
Run some cleaner eg Ccleaner with Ccenhancer installed, delete Temp files and Prefetch files
Download/install UnigetUI and update all available Windows apps applications, some will not as they may require manual command line updates, ignore them
Reinstall SDR sharp, i usually unzip to SDR desktop folder, run install batch file etc, restart PC and bingo or nothing again ?????
It may help, good luck
UTE-GE
I think it has to do with the .net being wrong. I remember one program needing to be run with .net9. SDRsharp needs to be .net8.
Will know more tomorrow left PC at work so not to smash it with hammer at home. 😇
UTE-GE
It was definitely the .net. Some where along the line I screwed it up. Lesson learned...
Now to figure out FMS scanner groups and slow scan rates for 16 air freqs. Sheesh...
