Motorola system: all control channels; L3H system: all channels.I'm trying to add a P25 system do I put control, control and alternates, selected, all then below that single or each frequency
How do I setup airspy r2Motorola system: all control channels; L3H system: all channels.
It's showing up on device manager but not sdrtrunkPlug it in. It should be recognized automatically.
How do scan more than one site should have them in the same create list and set the sensitivityUnplug it to reset it, then restart SDRTrunk
Go to your playlist editor, select the sites you want to scan and click "Play". Only caveat is all site frequencies need to be within a 10MHz bandwidth spread so in other words for example you can't scan a site containing 700mhz & a 2nd site containing 800mhz frequencies at the same time with only one SDR (Airspy R2 in your case)How do scan more than one site should have them in the same create list and set the sensitivity
Do I put all the sites in the same create channel list and alias also I haven't calibrate the R2Go to your playlist editor, select the sites you want to scan and click "Play". Only caveat is all site frequencies need to be within a 10MHz bandwidth spread so in other words for example you can't scan a site containing 700mhz & a 2nd site containing 800mhz frequencies at the same time with only one SDR (Airspy R2 in your case)
That must be what's wrong for as calibrating the R2 haven't seen anything how to do it
Neither are correct. It looks like you are trying to program a trunked system as a conventional system. When you create a new channel, select P25 Phase 2 Trunked system.Which one is correct, On the left I did frequencies to all and the configuration to single, then on the right I did selected and for each frequency
Perhaps the OP is referring to the "CPU vector calibration" found in SDRTrunk user preferences?Not sure where your getting calibrate from,
That's what I was talking aboutPerhaps the OP is referring to the "CPU vector calibration" found in SDRTrunk user preferences?
For P25 you can get away with just the controls & alternates. For DMR (MotoTRBO) & everything else you'll need all frequenciesDo I add all frequencies or just the control channel
Like this, with the max channels is that how many channels in each site, on the channels page it has new and different decoderFor P25 you can get away with just the controls & alternates. For DMR (MotoTRBO) & everything else you'll need all frequencies
